For those that have plugged this, did you drill a hole in it? I read some past threads and saw Thumper drilled an 1/8" hole in his. Is there a need / benefit ? Have you run without the hole drilled and then with the hole drilled?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
