Originally Posted By cbusters
If you have a column shift Auto the aftermarkets will not work without removing the selector light permanently.
Not true, the one from Year one is Identical to the original !!!!
here is a picture of one smile
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
