Thanks everyone. I tried launching in 2nd but it slows too much. Looks like I will try to fabricate a mechanical stop that I can remove and set back quickly as some of the rounds end up being nearly back to back. Next year I may focus on setting the car up for 10.0 and run both classes shooting for the same ET. Thanks to Whitedart I have heads that should make it an easy 10.0 combo.
if you can run several classes with the same number on the window..you will have a major advantage..I bet 10s with the new stuff will come easy.
