Around 1993 Chrysler decided to change the transmission designations to something that described them better. So a 518 became a 46RH. It breaks down like this.
4 = number of forward speeds
6 = an arbitrary number for its torque capacity. A 2 is less than a 6 and 6 is less than a 7 and so on. It does not correlate to an actual number, it's just relative.
R = rear wheel drive and
H = hydraulically controlled shifting.
A 904 became a 32RH a 727 became a 36RH a 500 became a 42RH.
When they went to electronic control the H was replaced with the E so an electronically controlled 4 speed rear wheel drive transmission became a 46RE, 47RE and so on. I'm not sure if there even was a 42RE but I don't know why there wouldn't be as they used the same valve body and overdrive unit as the 46's.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
