The aftermarket cores are not as good as the factory ones.I can understand wanting to replace it as you will have the heater box out.What is the difference in price from the factory core to the aftermarket? At work,I allways push for the factory stuff as it is usually better but sometimes the cost prohibits that.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
