I am looking for some real life experience from people who run max wedge size heads on their cars that mainly see the streets with the occasional strip run. Are you happy with your heads or do you wish you would have went with the standard port size? Did you lose more bottom end power than expected? When replying can you post you car's combo (model, weight, engine, rear ratio, converter, tire size, head mfg etc more info the better).
