Thanks.
What I am trying to do is utilize the orange, 3 pin molded connector in the dash aux. light harness to plug in some gauge lights. I took the ashtray out and put a two hole gauge panel in its place, fits perfect and didn't have to drill any new holes. The ashtray laamp actually plugs into the 3 pin molded connector which is now empty.
So if I can find the correct size connector then I don't have to splice into the light harness, I can just run the gauge light feeds right to the existing connector.
I could cut the ashtray light wire to use the connector but I don't like cutting original stuff if I don't have to.
