Originally Posted By Soopernaut
To the best of my knowledge, the Utiline beds had a combination of wood (at frame mount points and at cross members) and rubber mounts. The sweptline beds used wood blocks only.
I think you're 100% right & the only wood mounting blocks needed for Utelines is for the step mounting setup, & I just discovered Dodge Connection sell the one I need.
