I've used mild steel tubing for trans lines for years. If you splice it with a rubber hose, be sure you use hose that is for trans fluid. I put a little flair on the line, put efi hose clamps and a little white grease to get the hose over the small flair. If the line is bad for more then 12", I would splice in a steel tube. Gene
