For the money it takes to make a 383 into an hot motor you could go with a 440. Trans being a 727 should be able to handle plenty of horse power. For cheaper fun stick a cam, 4bbl intake and carb and a good set of headers on the motor you got. Depending on what gear ratio in the rear end and if it's a sure grip 8.75 or not you may want to upgrade.
