Thanks for the help. I was able to find an a/c big block water pump pulley two grove that I added with a 4 grove crank pulley. I rerouted the belts and problem fixed. It did not go a hair over 180. Lesson learned. Hopefully, this posts helps others in the future. Thanks.
