too small a master cylinder bore will give a soft low pedal .But will pull up fine as long as its not on the floor .
I think Mark Williams has a calculator to work this out
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
