Be interesting to see more info on the current combo, came compression etc.
Al, he listed the combo:
Originally Posted By kevinlc
The combination is a 15:1 451 cid with b1 original heads, sheet metal intake with two 1050’s, roller cam with .845 intake 285 duration and .766 exhaust and 299 duration ground on 110 lobe separation. Exhaust is 2 to 2/18 equal length. Trans is a 727 with a brake, 5500 stall, 14x32 and 5:13 gears.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
