.433 lobe with Hughes 1.6 rockers, Victor heads, PAC 1243 spring(same as comp 943), 1.900 installed height, peak power at 6800-7k.
Chip is running the same spring at 1.950 in his 572 hemi with .420 lobes, and when he’s spraying it, it turns about 7500 through the traps.
