Hi Guys, I have a 69 RR with a 383, TTI headers and a Robbmc Starter that isn't starting. I replaced the Battery & Starter Relay, still no cranking. I verified there is 12 volts at the Starter Solenoid. Is that it, does that mean the starter is kaput? Is there anything else I need to check before surgery? It's been starting excellent for 6 summers now, 18,000 miles, always garaged when not in use. Please advise, thanks, Paul "6T9RR"
