Hey are any of you guys having a ware problem with the w5s offset intake rockers, I run the mopar blue 1.5s and with a mid sized solid roller 260@.050 with .630 lift with 245 on the seat and 700 open and have lost .020 in rocker ware , it seams every season I have to re shim side clearance , also its a pain adjusting the exhaust valve< intake pushing on exhaust rocker> is this normal ware ? is anyone running a thin shim inbetween rockers to make up for ware? thanks Craig
