I'd use a bench vise as a press and a little heat on the pulley center before I tried to put it together with a hammer, same as you might pressing u joints or upper control arm bushings in or out. Years ago I screwed up a perfectly good TRW pump by trying to hammer the pulley back on. Cracked part of the casting...
