I have pushed against the rear bumper of my pickup with a common bathroom scale.
It is hard to find perfectly flat pavement so you should repeat such a test in the opposite direction.
My prefered test is to coast down an approximately 4% grade hill and measure the steady terminal velocity due to gravity. Do this at three or four different vehicle weights and you can estimate the three unknown aero Cd, tire rolling resistance and drivetrain friction loss.
