03-08 Hemis have a issue with exhaust seats falling out.. I would get a inspection camera to take a look inside each cylinder. the tensioners on the timing set like to wear out prematurely and improperly maintained hemis tend to spin rods easy, all these items should be looked at and corrected if using the early engines
