Originally Posted By Supercuda
Originally Posted By Centerline
You say you're using a "stock style" master cylinder. Is it a disk/disk master or disk/drum?
I got the MC/booster combo from O'reilly's and I ordered it for disc/drum.
That's your problem. You will never get the brakes working properly if you're using a master cylinder designed for rear drum brakes when you're actually using rear disks. You NEED a Disk/Disk master cylinder. That will solve your problem.
Nope
The only difference is reservoir capacity, just check it when doing an oil change, top off as needed and the residual pressure valve in the rear brake (front port) outlet, which he's already been told to remove.
Even removing the built in residual valve won't make it safe. There is no way I would use a disk/drum master cylinder on a disk/disk system. As the pads wear the pistons have to make up the difference and need larger amounts of fluid. That's why the reservoirs are larger on the disk side. It is ALWAYS best to use a master cylinder designed for the type system you're using. Jury rigging brakes is never a good idea.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
