Last week I replaced the heater core, re-assembled the dash, but the blower motor doesn't run when I turn the middle dial on the control panel. I checked the green wires behind the glove box, all of the connections on the AC/heater control are in place, I even pulled the blower resistor through the cowl to check the connection.
I checked fuses and relays, but I couldn't pull the green High Speed Blower Motor Relay attached to the fuse block on the left side.
Let me know if I need to pull the blower motor.
Thanks,
Tony
Tony
Retired Mopar Enthusiast
