If you decide to go with the 4.7 its not that bad of a motor.
Biggest problems was head gaskets and manifold bolts.
Good gaskets and SS bolts fixed mine.
The second is the lifters. Or whatever they are called. They trap garbage in them need to be cleaned often.
