I use A-100 15" wheels on the front and used later style 15" Wheel Vintiques on the rear with the smaller center. I epoxied later model caps inside of two of the larger caps to make them work.
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
