you can wire it up with either the dual field vr from 74 and up or ground one of the field wires and use the single field wire vr.
I have mine wired up to a single field vr and just ran a ground wire to the plug.
the plug was the hardest thing to get. had to go to a yard to find one that wasn't clipped off.
