Build a 46RE and use my trans brake with reverse manual valve body, had harden shafts, Billet drum ect and 1000+ HP is no problem.
Here is my sales pitch:
P NR 1 2 3 4. shift pattern.
NO kick down linkage
NO shift solenoids
NO governor sensors
NO controlle module
CRT has the only trans brake valve body with all gears on the manual valve & Lock up in any & all gears
also fits RH and all RE transmissions.
Can you out the power to it in OD as well or should it only be used for cruising?
