Wow thanks for the info
I'm a machinist
I'll make a couple sets no problem
The one in the carb had broke
I guess that tool looks like a extended ball allen wrench
I didn't know if it had some type of cable on the end to help get in there -like a speedometer cable thanks for the pics they do the trick and I can get going on this thing
There was one version where Bud had cut the end of the Allen ball end wrench, about an 1 1/4" off and reattached it with a stiff compression spring to join the pieces together by just sliding the spring over the two ends so it could flex... but this was his latest tool below
Mike
