I have to chuckle a bit at this talk of "high rpm" use with the stock 360-2 cam(.410/.410, 203/203, 109.5lsa)....... When the factory hp rating has it peaking at 4000rpm.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
