I don't know if this will help. When i did my Cuda the glass needed some TLC to bring back to life. As long as the scratches are just surface and not to deep you can do it yourself. There is a powder called erudite ( not sure if spelling is correct). you mix the powder with water and use a drill on low speed with a special adapter pad that comes with powder. The results are excellent if you the follow directions.
