I like the 942-16 comp springs for stock-ish cams in SB mopars. With a couple valve jobs installed height is around 1.700. The 901 needs a .06 shim. With a .06 shim the spring wanders. The 942 works with stock retainers and will have around 115# seat and 280# at .480" lift, without shims.
