Originally Posted By CRT
You have pics of the floor mods?
I thought crossmember & x member was the only mods needed
I dont have any, but on the floor it is all hammer work,most on the driver side,my factory console still works. The Xmember hump in the floor board has to be raised,if not done the driveshaft angles become a problem.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
