i am not converting. the old one was changed because it didnt work and now has a spectra unit. it reads m/t and it reads full but it is horribly inaccurate. a correct sensor reads 73m/t and 10 ish ohms full. and i believe 23 ohms at 1/2 tank. the spectra unit reads 73 m/t 10 full but about 42 or so ohms at 1/2. this registers about an 1/8th tank on the gauge
i want an accurate fuel gauge. thank you for the input.
