Just like old school drum brakes, it's a 3 step adjustment.
Step 1, loosen the cable adjustment so there's slack in the cable
Step 2, set shoe to drum clearance. This it at the wheel with the adjuster behind the splash sheild. Just a very slight drag.
Step 3 tighten the cable adjuster till there slightly more drag than before. Work the parking brake a couple times to ensure full release
Angry white pureblood male
