Originally Posted By mopar_leaner
This is what I have found out about this intake on-P4529117, the rpm range is from idle to 5800 and fits stage IV,V and production heads.
What is your source for this?
If it is an intake that is fashioned after the factory intake for a 440, I agree with Lew. Power will drop like a stone at 5200. The intake is the cork on a factory 440.
If you insist on that intake and want to up the power and rpm range, mill the divider, add an open space as room allows, and cam up slightly from stock.
