Hey John, the rear clutch clearance is set up with selective snap rings, the front clutch has a wave ring and by using various thickness steels you can set front clutch clearances, I have 5 frictions in the front and I’d like to not use a wave spring, what’s the clearance in the front clutch when a flat snap ring is used? Wave type have approx 0.075” for 5 frictions.
