IF you don't get all the brackets you need for alternator, I have modified alternator bracket with alternator for LA 318 swap to 5.9 Magnum that I ran for awhile. Fits well, lines up perfect and alternator had recent quality rebuild. PM me if needed. There was an issue with the head on the right side so the alt bracket had to be modified in order for me to do the swap. It wasn't a hack job either up
Facts are stubborn things.
