What cubic inch RB, Hemi or Low Deck? 499 RB
What brand block and what was prepped? Was block filled? factory RB block
What cylinder heads,who ported them to what CFM and CC chamber volume? Indy SR. MW ports. cut to 68 cc
Rocker arms,ratio and springs? Indy 1.5 . flat tappet cam 608/615 280/284 ( i think. i dont have the cam card in front of me )
Intake,carb,spacer? Modman with 2 edelbrock 750s
What headers? TTI step
Compression ratio using what pistons? 13 to 1 wiseco flat top
What stroke of crank and rods and brand? 4.15 eagle
Oiling system? Fuel system? external with milodon pump. fuel is all aeromotive
Transmission are you running? 727 with good drum and all good parts. ATI 8 inch 5000
What rear gear? Type of differential and axles? Moser 60 with 4.10 gear
What is your ET and MPH went 9.863 @134.07 this weekend at 3600lbs
match the parts. match the combo
Good to know.
Im aiming at 9.80's, my 3750#, 528, 95% street car has been 10.1 @ 134 but I want those 9's bad. Been told I have around 20% convertor slip so getting that sortedand rebuilt to 5000 plus some new shocks.
