Originally Posted By hemi-itis
What makes go in this direction? Have you been having issues with head gaskets? I had o-rings,tigged them closed and milled the head.
I did melt the head and the block last year when the gasket went out, but it was cause from the car finally starting to hook, G force started to pull my fuel shut off lever off causing it to lean out. My friend that tours the country tuning Blown Promods says it should be mandatory at the new level
