I would suggest lowering that 4.5 ms time below and above peak tq. In most engine conditions other than high load, 2ms would be sufficient and be easier on the coils.
I set the dwell time at 4.5ms since that is what the Holley data sheet recommended for 1.5 hp/cubic inch. I can tighten up the plug gap and reduce the dwell time easy enough.
