That would work, best answer is the most clearance you can get on the front and not have 2-3 flash since its a racecar. The more you run, the less heat buildup, more than a sprag roller would not help much if any. Depends on line pressure, lever ratio what shift kit, blocker rod or not, as to how loose front band can be.
