Just put a 360 in my buddies 48 Chrysler Windsor. Used a 98 Dakota front clip and factory engine mounts. I cut the front horns off the 48 frame and welded them on the Dak clip. The 48 front sheet metal, bumper and rad support bolted right on. The only other mod I had to do was to the inter fenders to make clearance for the 360 and the Dak suspension upper control arms.
