Hello All,
I have an older Turbo Action 727 Tranz Brake (#17998) that I'll be using for bracket racing. I have not used this setup before and I'm wondering which make of t-brakes you guys use and have proven to be reliable and great performers, especially without any tendency to creep...
I let a friend borrow my trans setup and he had to carry approximately 2000rpm for the turbo action brake to hold steady without any creep. If I run into this same issue, I'll be looking for a better brake that is rock solid without the need for extra rpm to function.
I see products from Cope, Griner, ATI, TCI, etc...
Which has worked for you?
Thanks!
