Lots of guys that run trans brakes and sticks with AFB's run with the rear air door wedged open. It's easy to try with a couple of pieces of 1/4" vacuum line stuffed into the upper corners of the rear casting above the door weights. Doesn't work well with foot brake or low RPM full throttle leave.
Doug
