Originally Posted By yellowgtx
Is the torque converter seal and the filter kit the same for the 65 727 Push Button tranny as for the 66 and up seal and kit.
What do the parts book show? Mopar change the converter, pump and gears in the pump in 1967 and up work
They also did away with the rear pump when they switch the shifting linkage to external away from the cables in 1966 shruggy
Call one of the better Hi Po tranny and converter company and ask them if the 1962 to 1966 converter interchange and order the seal from them up twocents scope
