One thing I forgot to ad was a 60" double door as well. My new trailer will likely be an InTech 30 or 32'er. I wont do a dbl coin floor again for the shrinkage factor and it will pusker and not lay flat. Heat is an issue where we are and will stick with the vinyl floor I've had. Easy to clean with a mop and added some diamond plate for the tires.
