If that's an add, that's two pieces of 1" tungsten, per end(actually, probably one 1" and one smaller piece). It's probably about $400 worth of work there, but it should be doable.
I'm uncertain why it's an add (or 100+gms) if the crank was "designed" for internal balance. What parts are you using? S/F....Ken M
