You won't find a kit. B1 heads have a different valve angle than say Indy's or Trick Flow, so there are no shelf pistons available. Plus, the amount of power that the B1 heads can produce are more than what most "Economic" rotating assemblies can handle. You are going to want some good parts in that combo.
[image][/image]
