Originally Posted By onig
Any truth that CM joints need to be "stress relieved"?
Not in thicknesses typically used in race cars. Proper TIG techniques to keep the heat affected area to a minimum and getting tight fits at joints is needed though.
As per Lincoln Electric:
Q. Do I need to heat treat (stress relieve) 4130 after welding?
A. Thin wall tubing normally does not require stress relief. For parts thicker than .120", stress-relieving is recommended and 1,100ºF is the optimum temperature for tubing applications. An Oxy/Acetylene torch with neutral flame can be used. It should be oscillated to avoid hot spots.
If the results don't match the theory, change the theory.
