Compression is just at 13-1 with victor jr. heads - I will be running C-12 to be safe its in a 64 dodge NSS. its screaming for bigger carbs - I have a solution for that - but that will be down the road a little
Nice piece. My 528" as pictured above made slightly more than that with only 10.5:1 on 93 pump gas since I still street drive all of my cars. Yep, I knew mine was going to want more for carbs which is why I went with the tunnel ram and two 1050's.
