Low reverse can use a stock part. The sprag takes most of the load on a LBA valve body, and all of the load on a non LBA valve body. Used for reverse only. For a K/D band I prefer the red material. Forward clutches use red Alto. Rear clutch works fine with the stock silver clutches.
Doug
