Does not have a built-in pressure regulator, so add that to the cost of the system. Also, External mounted ECU, so more wire to route and connect than the FiTech or Sniper.
Curious if this was made by FiTech for Summit? The instruction manual looks almost the same, and the hand held software appears the same as the FiTech unit?
